First of all, my rear defrost doesn't work... Second, my heater doesn't work worth a crap.... Which leads me to my question:
I want to wire in one of the lighter plug-type defrosters into the rear defrost wiring. The problem is, it only has a 15amp fuse in the fuse box. The defroster is rated at 16, and says to plug it into a socket rated at 20.
Also, I want to put one in the front, and wire it into the lighter socket. (it doesn't have to be hard wired in, I am fine with pulling the plug out when I'm done with it) Once again, it has a 15amp fuse in the fuse box, and the defroster is rated at 16, and says to plug it into a socket rated at 20.
Would it be safe to just put in a higher rated fuse, or will I need to run a new wire and use a relay of some sort to activate it? Thanks
Poverty produces creativity
