I did a write up on the process I went thru to change the odometer on my new Speedometer / Tach cluster to match my stock Speedometer only cluster.
This procedure is not intended to be used for any illegal purpose and is for reference only.
Good luck and I hope this helps someone out there!
~Phil
Procedure for Changing Odometer on White Face Cluster w/ Tach!
~Phil
