Okay so I got my new wiper switch from ericsmith32. However, I ahve been reading before I tear into my car. From what I have read, Iguess I have to make a jumper for this white switch to work? I did use the search feature everyone, but I am not 100% clear as to what to do to get it off and then install. Someone please help!
88 festy with white int. wipers. Help
If it's the right switch it should plug right in. Unless there's something I'm missing"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
its this one right here
88 Festy L (The White Thunder)
91 L came and gone, owned only 2 days
Yeah man, those swap right in! Unless there's a difference in the earlier model festy, but I haven't heard of anything
Edit: Here's a link to Tom's how-to...
Last edited by lanemeyer14; 01-27-2011, 03:52 PM."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Oh, mx6.....I looked at it quickly and thought it was a 626. That's what I get for trying to help!Originally posted by Pu241This is the unit he bought, I'm not sure this is a PnP type thing!
http://www.fordfestiva.com/forums/sh...ad.php?t=33496"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
You can probably make it work....just gotta fiddle with itOriginally posted by devon527 View PostSo it won't work? I just tried to put it in, only works on one setting..."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
I've used an MX6 one before. I never had to use any jumper wires on it. I had it in a '93, then a '91, then an '88, and now its in another '93. No problems on the installs on any car, it worked on all of them.No festiva for me ATM...
Okay so when its not all bolted in, I can get all the settings to work (at least I think so). But I try to put it in place and screw it in, it gets really tight and the washer fluid sprays the whole time no matter what. Is there something I'm missing? Do I need to switch over anything from the stock switch?
And also, the switch seems very close to the steering wheel, why?
Hey just wanted to let you guys know I did get it. The little white needle wasn't staying in the groove so it wouldnt move. Fits perfect and works perfect. Thanks for the help, and thanks again Eric
If it's still close to the steering wheel, you should get a later model wheel or bend the turn signal arm(s) to your liking. Early (1988-'89) and later (1990-'93) Festivas used differently dished steering wheels. Later ones were deeper dished to work better with the auto seatbelts or something like that.
My RX-7 and 1988 Mercury Tracer steering wheels need early style turn signal stalks so I'm not constantly fingering the signals as I turn the wheel.
It's not close anymore, I got it in right so it sits about the same as stock. I wasn't getting it in the slot in the steering column like it was supposed to. But thanks for the info!Originally posted by Safety Guy View PostIf it's still close to the steering wheel, you should get a later model wheel or bend the turn signal arm(s) to your liking. Early (1988-'89) and later (1990-'93) Festivas used differently dished steering wheels. Later ones were deeper dished to work better with the auto seatbelts or something like that.
Karl
