Tach Gauge Cluster Install.
  • Tach Gauge Cluster Install.
    Gonna try to install my new guage cluster tomarrow. I know I saw a thread with pics on here. I even down loaded it. I can't find it anywhere. And YES I searched, & went thru about 60 pages , page by page. Will anyone direct me to the correct Subject/thread please.?
    '93 Green L - ' Tiva
    If its a factory Festiva tach cluster it is just plug and play. Pull the old one out and put the new one in. If I remember correctly, the only thing you have to do is move the speedo cable to the other side of the dash support, you'll know what I'm talking about when you pull the cluster out.
    '90 LX
      Bingo! Pretty easy, pretty straight forward.
      My Musica! Click me!
        Thanks, I know that, but still want thread if possible.
          Don't forget to loosen the speedo cable from the tranny first(IIRC, 17 mm wrench/crescent wrench) or you'll have a hell of a time releasing the cable and electrical connects. Unless, you have tiny hands.
              Nope, got short chubby fingers, & shot arms. Thanks for info on wrench, will same a little time searchin' for the correct one.ohsnap
                I think what you are trying to say is you have, sausage fingers and patty hands!
                88 festiva lx, 2.3 turbo rwd swap in progress
                1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
                R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
                00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
                03' gt, full termi swap 700+ whp build
                sponsered by,
                pam pam's junk, dayton OR.
                Bob's ok tires, salem OR.
                Clausen Truckin', keizer OR.
                  It was a 19mm on mine.:colors:
                    Ummm....maybe.:snorting:
