Push button start
  • #16
    Alright, here's what you do...
    Leave the broken key in the ignition in the 'on' position.
    You're going to cut the wire AFTER the ignition switch for Accessory, Run and Start.
    You'll have two switches, one each for accessory and run. You'll also need a momentary, pushbutton switch for start.
    I'll throw together a little wiring diagram and post it up in a second...
    -Zack
    • #17
      last year it cost me $60 bucks and a hour for a locksmith to come to my house,
      remove ignition,remove broke key, make new key, and re install everything!
      Call a locksmith.... See what your options are with them first... My .02
      93L sold. First FESTY!
      91L blue monster "BP swapped!" Robbed of its Heart for other Festy!
      91GL blue bandit(thanks to sparky) Sold twice! lol
      89L (thanks again to sparky) "SCRAPPED without my permission!!!!:nono:
      93L Clean Green Machine! (Thanks to Sedat)-Sold to other member!
      89 Auto LX Wrecked and stripped. violin
      93GL Sold Too Soon!
      91GL BP powered, ALL OPTIONS! banana time
      • #18
        -Zack
        • #19
          Thank you i will see if i can do it.
          • #20
            You can. Post back if you need any help but if you understand how a lightswitch circuit works, you should be able to figure this one out.
            Just remember, you're emulating the ignition switch with external switches... that's all.
            -Zack
            • #21
              nice diagrams crazyrog
              sorry hofficergrover, I couldn't tell if you wanted to fix it or not at first. but I think push button starts are great! are you going to kind of hide it or put a button somewhere else to complete the circuit so someone can't just jump in and go? just a thought
              Walth
              Festiva #1: 91 Red L 4/5
              http://www.fordfestiva.com/forums/sh...ad.php?t=27981
              • #22
                you can put a micro toggle under the dash after the relay to cut power to the push button.
                88 festiva lx, 2.3 turbo rwd swap in progress
                1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
                R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
                00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
                03' gt, full termi swap 700+ whp build
                sponsered by,
                pam pam's junk, dayton OR.
                Bob's ok tires, salem OR.
                Clausen Truckin', keizer OR.
                • #23
                  No problem man
                  Will hide the toggle switches but the push button will be in plain sight.
                  • #24
                    Maybe a secondary 'KILL' switch that's in plain sight and labelled would be a good idea...
                    -Zack
                    • #26
                      looks pretty sweet! try it out yet?
                      Walth
                      • #27
                        Yeah it been working for like two days. Also i didn't cut into the festiva harness at all i used some plugs off of a old steering column that was broke and some relays form a ford ranger. Works great!
                        • #28
                          +1!! sweet
                          Walth
                          • #29
                            Video or it didn't happen.
                            Good job by the way!
                            -Zack
                            • #30
                              lol i will get a video tomorrow for you guys.
