Not sure if in right area to post it in but please move it needed.
Ok I have a 92 l that the key has broken off in the ignition i can remove it no problem but have to start the car with a screw driver. I don't like searching for the screw driver when it falls of the dash so i would like to do a push button start. What do i need to tap into to control power? I want to leave the key in and on so it don't lock the wheel. And have a toggle switch control all power. So where is the main wire that controls all the power? Like should i tap into it at the fuse block or out under the hood? What guys think
Thanks
Thanks
I could never steal a man's Festiva if it didn't have a key.
