Installed a CAL awhile ago. Can't get it to work. Checked wireing, no breaks I can find. New bulb. Tried bigger hammer, nothing helps. I do not have a multimeter yet.:cussing:
Cargo Area Light
Originally posted by Tex Law View PostDoc,
Sorry to hear a bigger hammer didn't work....perhaps you could try a Kimber Classic. Just saying...it's the electrical gremlins that get me every time.Ha! Don't have a Kimber, but I do have a Springfield. Too close to gas tank,but thanks for the suggestion. I installed the one with the switch, not the one with the latch switch( did that make any sence?). Things start and stop workin' on a regular basis. Hazard switch didn't work until I took dash apart. didn't do anything to switch now it works. The windshield wiper switch where you push forward didn't work ,now itdoes. Weird stuff. Turn on dome light & buzzer comes on.:banghead:Originally posted by xaero_81 View PostDid you install the latch with the wire on it too? I don't think it works unless you have that latch. Could maybe try grounding that wire and testing to see what makes it work.
my personally installed a/c works great but every once in a while gotta tap the relays under the hood.....oh and my escort dome light only turns on if i wiggle the switch.... its an old car and it has a few kinks but..whats the fun in owning a car if al you do is drive it
...all the new cars have a huge piece of plastic garbage covering the motor...its a shame...
91L 5 sp, 175k,a/c ,KYB gr2,Fms Lowering springs ,13" konig's ,09 tiburon seats, 7" Pyle in.dash,kicker ds400 all around,Kicker 400.2 powering 2 Kicker cvr 10", 30k hid's, hopeful to find a xr2 to swap b6t from....
2010 mazdaspeed3 stock... for now
They're relatively inexpensive. That or a test light would work just to know if you're getting voltage at all.Originally posted by navdoc101 View PostInstalled a CAL awhile ago. Can't get it to work. ... I do not have a multimeter yet.:cussing:
Grab another relay from the junkyard and clean the switch in the dome light!Originally posted by phyaz91 View Postmy personally installed a/c works great but every once in a while gotta tap the relays under the hood.....oh and my escort dome light only turns on if i wiggle the switch.... its an old car and it has a few kinks but..whats the fun in owning a car if al you do is drive it
I bet you can do that if you've installed AC yourself
I understand it's fun to put up with your car's "personality" sometimes too though
-Zack
I have to get some soldering + modifications done on my spare latch.
The young guy at a non-upick yard said the latch had to remain with the hatch. All he gave me was half of the contact. I have to resolder the wire on and solder a copper extension onto the existing half. It must contact the arm which is in the open position in the picture.
my 88 lx hasant worked and neither has the dome light since i swapped in the efi harness!? i just got used to having no light lol i wish it worked tho
88 festiva lx, 2.3 turbo rwd swap in progress
1999.5 f-350 4x4 7.3 gtp38r 5" exhaust ect.
R.i.p. 1990 Western Star 5964s 3406b 530whp (4.2mpg!)
00' western star flat top ex, 600hp 6nz 2250tq, 18918b, 3.55, full lockers, 6" straight pipes
03' gt, full termi swap 700+ whp build
sponsered by,
pam pam's junk, dayton OR.
Bob's ok tires, salem OR.
Clausen Truckin', keizer OR.
I didn't know that was possible...just the harness or engine as well?Originally posted by 1988festivazoom View Postmy 88 lx hasant worked and neither has the dome light since i swapped in the efi harness!? i just got used to having no light lol i wish it worked tho
isn't is a blue/red wire and a green one? I haven't looked at these in SO long...but I do remember that the wires are switched that you connect them to. They don't correspond. Do a search for it, or check some of Skeeters threads as he may have commented on it. I could also take a few pics of his CAL and wiring as well...Originally posted by navdoc101 View PostInstalled a CAL awhile ago. Can't get it to work. Checked wireing, no breaks I can find. New bulb. Tried bigger hammer, nothing helps. I do not have a multimeter yet.:cussing:
I'll ask nate to post a pic when he gets home and send him the link. there's only a couple wires back there and if you switch them it might work but it doesn't help that I don't recall the exact wires. lol. hopefully nate can post.
the entire harness in my car was changed, the only things that dont work are, cigarett lighter outlet, dome light, cargo light, not sure why but i have power nowhere on those circuts.
sponsered by,
im a perfectionist as well !! will be working on everyones kinks april 16th at the meet!Originally posted by navdoc101 View PostNot so much.:protest: I want it to work perfect! :sad6:93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
RJ
I thought you made a thread for yours? or did you?? I'm not about to [threadjack] or confuse two different cars here...
