Since i had a 2006 ranger i can add insight. You flip the ground and high beam to convert a 9004 to a 9007. The ranger headlights in the ranger are held down by a type of channel strip of metal that locks them into place into the core support. Making your own can be as easy as snipping on the festiva support with tin snips and bending the metal back so it holds. What i would be weary of is the housing bouncing along on the road looking like you are flashing your high beams. This has happened to me on past projects where i didnt weld things and just tried to do it quickly. If you get it as close to how the OEM fastens it should be fine tho.
I would like to see pictures of the back of the ranger light up against the festiva area, how it's put in
