88 tach cluster?
  • 88 tach cluster?
    I am trying to get my tach cluster working on my 88.. I have tried hooking up a wire to the back of the cluster from another thread but after trying all combinations I had no luck. It looks to me like the back of the tach there are 3 connections one power one ground and one signal input. I'm blessed with a car that that isn't wired for the tach so any help would be great. I have an aftermarket tach installed on the dash so I know my signal wire is good. But what I'm thinking is maybe the plugs in my dash may not have a power supply for the tach? Or a ground for that matter so should I manually wire in the dash tach like I did my after market 12v, ground, signal.
    1989 Ford Mustang GT 5.slow
    1996 Ford F-150
    snatch a hole efi harness and we will save your car
    93 L B6T DD http://www.fordfestiva.com/forums/sh...ad.php?t=37751
    RIP_90 LuX http://www.fordfestiva.com/forums/sh...ad.php?t=32249
    RIP 88 LX / B8-MEhttp://www.fordfestiva.com/forums/sh...ad.php?t=26398
    RJ
      Yeah snatch one and come down this Sunday for my mini meet !
      -M3NTAL MARK! Woo!!
        am i invited?
          Originally posted by takeone51 View Post
          am i invited?
          no we dont wanna finally see your full built b6t car with now g series and exhaust on a standalone ecu !!!
          u better come!
          RJ
            On the back of the cluster, if you trace the tach pins you should find a screw along the strip from the pin. If the screw is missing, put one in. I am not sure why, but I have heard about this happening and the missing screw was the culprit.
            My Fleet:
              Yeah I tried this without any luck. I traced where the wire should be and nothing happened so is there power to the tach will it hurt it to put 12v to one side and signal if I run my own wires. All the screws are there.
              1996 Ford F-150
