Can anyone tell me how to hook up a aftermarket speedometer in my festy..
custom gauges question?
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
Easiest is to get a JY speedo from another Mazda; late 80s - early 90s. I'm presently using a 140-MPH 1992 Protege speedo.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
yea but i want all phantom II gauges in my festy an i wanna make a custom gauge setup were my oem one sits so kinda wanna know how to install these gauges properly thanksFrankie
that is cool but i wanna use a certain type of gauge this would be a long $$ process anyway concidering the gauges start at 75 for a tiny ony i just need to know how too hook an aftermartkey speedo to a b6t an work (i like the GPS thing tho wicked)Frankie
Look it up , speedhut.comOriginally posted by lil red rocket View PostHow much did that speedo set you back?
Heres mines , not GPS though , but it takes any signal from the VSS or anything that comes out the tranny. Once you hook it up , you travel 2 miles exactly (highway markers) and you press the button to set it. Then it know that Ex: 2543 signal counts = 2 miles.
Expect 550-700$ for a full kit. I think its 140+ for a speedo.
wow thats cool i was going to get phantom II gauges ps i love what your looks likeFrankie
Should be simple hot and ground , your trigger or what ever the correct term is would be the yellow wire with green strip connected to the coil just above the left strut tower !
Have not done an aftermarket yet but I'm sure I will be corrected if I'm wrong !
Being so I answered your direct ?New build on the way .
Re: custom gauges question?
I remember seeing a gear to electric adaptor. Been a while though. My jeep had gear driven electric signal, so it can be done.Last edited by Huli; 02-21-2013, 09:55 PM.HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
"CL4P-TP" - 93 Festiva L
