custom gauges question?
  • custom gauges question?
    Can anyone tell me how to hook up a aftermarket speedometer in my festy..
    Frankie
    http://www.facebook.com/#!/profile.p...00000110128487
    Easiest is to get a JY speedo from another Mazda; late 80s - early 90s. I'm presently using a 140-MPH 1992 Protege speedo.
      yea but i want all phantom II gauges in my festy an i wanna make a custom gauge setup were my oem one sits so kinda wanna know how to install these gauges properly thanks
      Frankie
        I went with speed hut gages with the speedo driven by GPS. Cool but not cheap
        money pit
        No spitters were I work, you swallow it all. The Company feels if you already have it in your mouth why waste it.
          that is cool but i wanna use a certain type of gauge this would be a long $$ process anyway concidering the gauges start at 75 for a tiny ony i just need to know how too hook an aftermartkey speedo to a b6t an work (i like the GPS thing tho wicked)
          Frankie
            How much did that speedo set you back?
              Look it up , speedhut.com
              Heres mines , not GPS though , but it takes any signal from the VSS or anything that comes out the tranny. Once you hook it up , you travel 2 miles exactly (highway markers) and you press the button to set it. Then it know that Ex: 2543 signal counts = 2 miles.
              Expect 550-700$ for a full kit. I think its 140+ for a speedo.
                wow thats cool i was going to get phantom II gauges ps i love what your looks like
                Frankie
                  I like this RX-8 gage cluster down at the bottom of this link.
                    Should be simple hot and ground , your trigger or what ever the correct term is would be the yellow wire with green strip connected to the coil just above the left strut tower !
                    Have not done an aftermarket yet but I'm sure I will be corrected if I'm wrong !
                    Being so I answered your direct ?
                    New build on the way .
                      So, hooking up a Electronic speedometer is possible?!? Even with the Transmissions having the gear?!? That is way to cool.
                        Unless you have cruise control, there is no electronic speed sensor on a stock transmission.
                        -Zack
                          Re: custom gauges question?
                          I remember seeing a gear to electric adaptor. Been a while though. My jeep had gear driven electric signal, so it can be done.
                          HULi ---------------------------------------------------------------------------> Any-where, any-way, any-time.
                          "CL4P-TP" - 93 Festiva L
                            It can be done. I haven't found a source for the sensor, but it might be compatible with Escort/Capri/Protege/323 speedo cable sensors. I'd be interested because it'd be fun to build an MPGuino.
                            -Zack
                              Napa sells the sensor.
                              91GL BP/F3A with boost
