Is the goal just improvement or are you going for top mileage in the spring?
Front Air Dam! WHAT???
Adding a second nut and maybe a lock washer to each end of the turnbuckle will stop it from spinning but the real fix is an aspire rear axle!Blue 1989 Festiva L 1.3 carb 160K+, Aspire 5spd, Aspire swap, Tach, Added A/C, Intermittent wipers.
Aqua 1991 Festiva L 1.3 FI 200K+, 5spd, Aspire swap, tach, Intermittent wipers.
Green 1995 Aspire 1.3 FI 95K (RIP Saved my 18yo sons life)
The turnbuckle I installed was too skinny to fit a nut inside (I did think of that, but it did not work......Out came the clamp, lol):pOriginally posted by Burnrate View PostAdding a second nut and maybe a lock washer to each end of the turnbuckle will stop it from spinning but the real fix is an aspire rear axle!
The nuts go on the outside!Blue 1989 Festiva L 1.3 carb 160K+, Aspire 5spd, Aspire swap, Tach, Added A/C, Intermittent wipers.
Holy crap!!!!! What kind of numbers did you see in the past?
edit: DDDDDUUUUHHHHHH never mind.Last edited by 91mcnasty; 01-13-2012, 01:40 PM.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
License plate screws and bunge or bracket under hood lip to
upper radiator support ?
get a slightly wrecked grill and bond it to the grill
and reinstall ?
do you have all your tricks listed somewhere?Reflex paint by Langeman...Lifted...Tow Rig
One of the better mileage improvements I have inadvertently made was by installing a new oxygen sensor (BTW Aspires have 2 of them). I don't know how you test these things but, much like spark plugs, sensors do seem to wear out in the long run.
Monitoring sensor activity and length of time to warm up
is the best way to tell when they are getting weak. You
play with them enough and you will know. Just watching
the voltage play with a 3 dollar HF digital will do it. The
upper will always be more active and it controls mix. If
only one is present this is it. The 2nd or downstream will
be like the upper but not quite as active, its purpose is to
tattle tale a bad or missing cat. There are videos...Reflex paint by Langeman...Lifted...Tow Rig
I do like the back end. you should make a fiberglassed one. Have you done weight redux as well? Your fenders only need 3 bolts to hold it on not 6, and so on...lol1993 GL 5 speed
