a question for those of you with a trailer hitch
  • a question for those of you with a trailer hitch
    Ok so I'm in the process of building a trailer hitch and small flat bed trailer for use behind my festivas. The car I'm gonna be pulling with is my 91 gl with a cammed b6 swap with stock suspension. My question is what is the weight/ tongue weight of the trailers that you guys are pulling behind your festys? I'm just going to use the trailer for junk yard runs and trips and such nothing too heavy. I'm using a stock festiva beam for the axle so that I can use the same spare for the trailer as the car. Any thoughts or suggestions?
    Justin Craig Paola Kansas my 4 passions, demolition derby,Ford 2.3s, my festiva and my kids
    My half Festiva trailer is about 70lbs tongue weight empty, I pulled it loaded down with about 500lbs of crap in the trailer. Other than the obvious load it did ok on the highway with a camed b6 in mine.
    Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
    Dennis
    93 GL In progress BP/hydro G
    15 Mitsubishi Mirage daily
    88 Dakota tow pig
      B3..I don't go over 2000lb trailer weight and keep my tongue weight
      between 50 and a 100 lbs. Bulky loads should be centered so that
      side wind gusts will push on your axle and not the hitch of your car.
      Do not over drive your stopping power.
      Do not go climb steeper than 6% grade on gravel
      Use a 2 wire electronic flasher and a converter
      for trailer lights. That is the short list for happy towing!
      You could rig surge brakes on that trailer!
        I'm hoping/assuming you have an Aspire brake swap? I wouldn't even consider towing anything more than about 500 lbs without the better brakes.
          Thanks guys I'm trying to get some facts before I start this build
            Brakes?? When ever we fill up the little
            thingy with fluid it makes a mess under the car so
            we just use the one between the seats..:p :p
              The single axle (old stub nosed chevy van front axle) 4X8 trailer I built using 4" "C" channel weighs in approx. 710 lbs., car 1860 lbs. me, 145 lbs.
              Seeing the look of the guy at the scrap yard handing me the weight ticket @4180 lbs, priceless.
              That was only 1460 lbs. of engine blocks.
                Poor scrap yard guy! He didn't get any pics and nobody will
                believe him! That's enough to drive him to drinking!
                  Yeah nobody would believe that
                    Not a pic of the rig in action (I didn't take any) but a scan of the weight ticket.
                    Hopefully this is visible.
