i know some of you are using prelude seats. i love them and had to have a pair in mine so i picked some up. the other night i test fitted them and the two front bolts worked but in the farthest back position it still wasnt as far back as i would like them. so does anyone have pics of there's and how they mounted them?
prelude seats?
mattswab has a thread on how to perform this swap as pretty much a bolt in option. I forget the year but they are later years. I know the early year seat are a lot more fabbing. I have had both.
here is the thread....starting at post #34 I believe. He used 93 seats...
ya know, it's been 6 years and i STILL havn't swapped in the EGT bottoms onto the festy seats in Scrappy... could it be?!?! i have too many projects?Trees aren't kind to me...
I know when I fitted the 90 prelude seats for ENEMY_ 's zefstiva I had to chop and reweld all 4 corners of each seat slider to get them in.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
92-96 are the seats that are closest to fitting....just need a few tabs"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
im running prelude seats...
my brackets are very similar to teh ones on post#34 in that linkLast edited by fastivaB6TG25MR; 03-29-2012, 02:52 AM.I know its a piece of crap but im still faster...and its 100% legal!!!!!
I love my prelude seats! So Comfy!-------------------------------------------------------------------------------------------
My Musica! Click me!
Originally posted by htchbck View Post^^ Because the best reason to ditch the Festiva seats is to have a new base on it, not a new back with the old base
At least to me, that is.Kinda, but more like modifying frames so that the Prelude upper goes onto the Festy bottom.Originally posted by rbrown View PostSo you put the Festy bottoms on the Prelude uppers?
The bottom rails and frames (with minor, no-weld mods) bolt to the Prelude backs. The Prelude cushions will fit the Festy rails and frames. I'll take pictures as I do it.Last edited by DON SVO; 10-02-2012, 01:54 PM.1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
honestly Don...you are doing way more work then you need to. If you have 92 to 96 seats...then you oblong one of the rear mount holes and add a piece of barstock (with bolts, no welding) and that is it. The fronts match up.Originally posted by DON SVO View PostKinda, but more like modifying frames so that the Prelude upper goes onto the Festy bottom.
But you can do it any way that floats your boat...
