Whats that ? U want something diffrent ? Yep i did to , i took the green dash and preformed a light modd i removed the cluster pulled the stupid green lense from the top of the light display ,two silver screws and it lifts off , removed two bulbs in four light harness the two bulbs i left in i took and lightly sprayed with a clearish orange tint hobby paint , and re installed the cluster minus the green lense and two bulbs , four bulbs were way to bright it killed the green tint on the numbers , what do you guys think ? I love it , its cheap easy modd 20 mins
Dash cluster light modd
Whats that ? U want something diffrent ? Yep i did to , i took the green dash and preformed a light modd i removed the cluster pulled the stupid green lense from the top of the light display ,two silver screws and it lifts off , removed two bulbs in four light harness the two bulbs i left in i took and lightly sprayed with a clearish orange tint hobby paint , and re installed the cluster minus the green lense and two bulbs , four bulbs were way to bright it killed the green tint on the numbers , what do you guys think ? I love it , its cheap easy modd 20 minsTags: None
I tried to change the bulb size and play with the analog cluster, but gave up when I saw the digital one. Some day I will install my orange digital cluster.Last edited by bravekozak; 06-01-2012, 06:38 PM.
I'm gonna remove the upper light bar and replace it with a diffused LED strip or fluorescent bar, then replace the backlight bulbs with blue LEDS and paint the orange needles with luminescent blue paint.
Of course, after I get a damn white face gauge set.
And i was doing everything on the super duper cheap guys , im not trying to led or neon those are great ideas but like i said these cars are not for me to dump cash flow into , i wanted to show what u can do for a budget mod not trying to empty ur wallets out maybe someone would like a change on the ultra cheap
Originally posted by runner406 View PostAnd i was doing everything on the super duper cheap guys , im not trying to led or neon those are great ideas but like i said these cars are not for me to dump cash flow into , i wanted to show what u can do for a budget mod not trying to empty ur wallets out maybe someone would like a change on the ultra cheap
Last, file out the holes on top of the cluster so it's a single, long hole instead of one over each gauge. that will make the light even over the entire gauge face instead of highlighting each of the larger gauges.
