bit of an all rounder really - interior, exterior, etc.
  • bit of an all rounder really - interior, exterior, etc.
    i have already ripped the aspire brake swap guide into the forums as i think it's pretty good
    here is a link from the same source
    there are quite a few guides here that i think can be adaptable or at least give people some idea as it's all mazda/festiva/kia/familia related info (sorry if i missed a few models or incorrectly labelled a car to be on the list when it wasn't, but it's late.)
    if anyone wants to suss out any info and make writeup threads.. go ahead
    Avg Economy:
    Highway - 7.32L/100km
    City - yet to be determined.
    there is also some notes from the publisher as well
    In this section you will find various walk-throughs on installations of peformance items, as well as general maintenence. Hopefully using these How-To's will save you time and prevent you from messing up the install like I have done with so many things (springs, shifter, calipers). If you have a how-to that you'd like to submit, please email it to me at: groharlem@hotmail.com I will give full credit for your work (^_^)
    Coming soon:
    -Take Apart G-series transmission & swap bellhousing
    -Remove transmission from car with engine still installed
    -Install 01-03 Honda Civic Projector headlights into your MX-3
    -Install a Mazdaspeed Protege 2-way (clutch-type) Limited-Slip differential, manufactured by Tochigi Fugi Sangyo into your G-series transmission.
    i think there is also some good coming soons as well (as long as they are adaptable to festiva's )
    there's an email address if anyone wants to try to follow it up.
    Avg Economy:
      Thanks!! I used to have that saved but lost it some how. Glad you found it!!!
      '93 Green L - ' Tiva
        I don't know if I'd take advice from someone who recommends installing scotch clips in an ignition system. Is a soldered tap splice really that hard to do? I never had a problem making them.
          maybe replace the scotch clips with something else like real soldering skillz and heatshrink instead.. use the same technique as it seems sound but the fastener/method of fastening/soldering is mainly the issue here.
          Avg Economy:
