Hey guys i've done a popular upgrade on this site. The previous owner of this festiva had cracked the plastic around the radio and I took some JB weld putty and glued it back together. Then I cleaned it sanded it down and painted it a similar red to the exterior of the car. I'm pretty happy with the results so check em out.
Interior Plastic Painting
Looks good!
My 5 cents:Originally posted by Mercilesslee View PostDo you think painting the door pockets would be a little too much red?
you should get the center airvents in original color OR side airvents in same red. Would balance the color.
I don't think it would have too much red, if door pockets would be also red, I would suggest to paint the surrounding of gearselector..Hi! Do you wanna ride with me? I have red cabrio, it has the biggest engine what was available when the car was new. It also has about every possible accessories what was available then.
It's -89 Mazda 121 with 1,3L carb engine banana time
Paint the lip of the pockets red, paint the top of the arm rests red, and paint the knobs on the vents red, and ring the tach & speedo with a 1/16" red pinstripe. Less is more.In love with a MadScientist!:thumbright:
I used KRYLON fusion plastic paint. It was 7.99 at the hardware store. I sanded the plastic a little bit but I know if you want a really professional look you can buy adhesion promoter spray. It's a clear spray that makes paint stick like crazy and will require less coats. This with some sanding took me 4-5 coats.
Nice paint work, I like the redBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Nice interior paintings. I've done the same to my pride, it's in my sig.
