So...I know im not the only one who likes to have a drink in the car. If you know what i mean.....
Soda, or Water, or...Gatorade.
Heres what i started with.
I had a Cubby under the dash like some of you have. I wanted to be able to use the cubby as a cubby and also as a drink holder.
Then since i hated the way it looked i decided to go with Cup Holder MK2
This design was much simpler. Also it only involved drilling 2 10-32 clearance holes in the top of my cubby that no one will ever see. Even if they took it out they are so small it wouldn't matter.
You can see the overall completed assembly here
Heres 1st gear
Heres 3rd gear
Heres 5th Gear
Also 4th for comparison.
You can still use the cubby as a cubby if you want.
Heres a Gatorade in either slot. Drivers side or Passenger side.
If you guys are interested ill post up a drawing so you can make it on your own.
Mines made out of PVC plastic sheet, I needed to heat it to bend the 15deg angle. Then fabricate the metal Brackets to hold the drink.
Its very Sturdy and i feel happy with the overall product. Not sure if ill paint it yet tho. I don't know if its worth it.
Heres 1st gear
Heres 3rd gear
Heres 5th Gear
