Gas Hood Struts in 15 Minutes
  • #31
    Originally posted by 1990new View Post
    Great deal... let everyone know where you got them.
    I installed one of the struts and decided that it was more than adequate on its own. I gave the other one to my dad for his Festiva . Here is a pic of mine installed. One alone won't raise it by itself but it will hold it in about any position past quarter of the way open. One thing I love is that the strut brings the hood up tight to the latch when you pop it, as opposed to having to squeak your fingers in the tiny little crease to make that space.
    My Fuel Log
    • #32
      I recommend redundancy. Just in case one fails, you won't end up with broken fingers, or a big bump on your head.
      • #33
        Ordered mine thanks for the thread guys
        -M3NTAL MARK! Woo!!
        • #34
          Originally posted by mikeyjd View Post
          http://www.ebay.com/itm/370849775230...84.m1497.l2649
          I noticed the duct tape over the cowl intake, cowl rusted out and leaking?
          Jack Byrd,
          1991 Capri
          1988 Festiva LX, 240K
          1970 Chev C10
          1977 Airstream Argosy MH
          • #35
            Probably for aero
            91GL BP/F3A with boost
            • #36
              Originally posted by bhazard View Post
              Probably for aero
              Yes. Although it lies below the boundary layer of air flow on the hood, cowl seals have a slight effect on airflow into the grill opening.
              My Fuel Log
              • #37
                so easy so fresh thanks for this thread OP you da man!!
                -M3NTAL MARK! Woo!!
                • #38
                  So do you need 4 ball studs for 2 struts, or just two? because it it really looks like you need 4.
                  • #39
                    Yep. You definitely need 4 if you Install struts on both sides.
                    • #40
                      I assume these are the correct ball studs?
                      • #41
                        Yes those are the correct size. Did you check amazon those are a bit expensive.
                        • #42
                          Definitely cheaper on Amazon.
                          • #43
                            I did 2 struts a while back and LOVE IT. Sometimes I will open my hood just because it is cool to do so now. lol
                            -Bryant
                            • #44
                              I noticed that even with two hood struts, the hood goes up much slower in cold weather. I really appreciate the fact that both prop rod clips were able to be removed and that I was able to use one of the holes to mount the cruise vacuum ball. It is perfectly located.
                              • #45
                                Yeah, that is why I need to get a new one for my hatch. I noticed it last winter, but now that I also have the wiper motor in there now in this cold weather the hatch falls unless the strut is fully extended.
                                But even when warm out, it wouldn't fully open, I would have to assist it the last few inches.
                                Luckily I can have autozone order one for $12
