Originally posted by drddan
Pontaic Montana seats
I don't believe so. I am quite certain that you can install 88/89 seats directly in 90-93 Festivas. To go the other way, you need to take the rear inner floor brackets along with the seats. Can anyone verify if the studs are under the ebrake console in a 90-93?Last edited by bravekozak; 08-10-2013, 06:44 AM.
Has to be the seat belt relocation. I see no other reason.Originally posted by greywolf200 View PostThis came about because of the auto seat belts on the later models?Last edited by drddan; 08-10-2013, 09:14 AM.Dan
Dr., I deeply regret not finding the crowfeet. I searched, but they are probably at the bottom of some storage bin.
These are the only ones I found .Last edited by bravekozak; 08-10-2013, 03:54 PM.
Dang the luck!
Thanks for searching!Last edited by drddan; 08-10-2013, 07:15 PM.Dan
Yeah, the pre-90 seats have the inner foot going up and in toward the center and the 90+ seats go back and down.
I got to looking at the 90+ foot again and it dawned me to compare to see if I could use it on my 88.
Sure enough, both style feet are the same height AND the distance from rivet hole to bolt hole are close to the same. I'll just weld the 90+ foot on the angle of the 88-89 foot. Problem solved!
I need a spool of wire for my welder. It has fluxcore wire in it now, and a while back I bought a bottle of gas to weld with, and have the gas conversion kit. All I need is the wire and I can go at it.Dan
There was talk, but no new post's .... Anyone hit the JY and get a set of these seats?
I got the welding wire, took some mearsurements, cut 4 pieces of tubing for the 1 3/4 height diff of the festy floor mounting, but I ran off and left them at work! I wont be back 'til monday to get 'em! Sheesh.... Now I have to wait 'til I gots 'em here at the house to finish.Dan
dr, did you see how I cut one piece of rectangular tube in to different spots and use one piece for each seat? It is strong, a perfect height and jas perfect mounting points for a perfect fit. Take a look at my outside rear mounts again. It would probably work for you since the seat widths are almost identical.Last edited by bravekozak; 08-15-2013, 08:05 PM.
I left the tubing for the seat extension swap at work (see post#69) < (heh heh!) I had some vacation I used thursday/friday and went camping. Just got back to work today.Originally posted by william View Postup dates .?? i was going to pick up some of these seats but I'm waiting to see the end results.
William, the seats will work, no problem! I will try to get to 'em this friday, and if'n I do, I will post the swap and pics.Last edited by drddan; 08-20-2013, 03:39 AM.Dan
I think I paid $63 total for both seats. I had $55 credit with them and it was $7/8 extra. PnP has a price chart on their website. I got the 2nd row seats which are manual seats. Electric are more $, but I didnt want the front elec. seats.Dan
