ok I found a nice set of 14 inch rims. I don't know to much about offset. does anyone know what a +38mm offset will look like or how it will fit??
rim offset
rim offset
1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
They will fit, but probably will require 1/4 - 5/16 inch spacers in the rear to clear the rear strut's spring perch.Dan
We need to know rim width too. I run 13 X 5.5" VW alloys with 38mm offset. They clear my Aspire struts fine but will rub the rear fender lip with 175/70s.
ok they are 14x6 with +38mm offset.1990 Red Festiva STOCK "pregnant roller skate"
Stay under a 60 height tire, preferably 50. Like 175-185/50/14 or there abouts.
You can pick the overall tire diameter by changing that middle number.
You may know this already, the first number is the width of tire in MM, and the second number is the height, in percentage of the width, the last being the rim size.
You can stay close to the stock dia by using a tire with a smaller number in the second place.
Here is a tire size calculator, which you can use to determine what tire height will match close to the stock size tire. This will help clear the tire/strut by using a tire that will fit better.
Dan
90, the rims you have will fit without issue. i recomend you use a 165/60/14 so that you won't have to worry about rubbing and you'll also be >.< this close to being perfectly accurate on your speedo/odoTrees aren't kind to me...
thanks guys for the help been year in progress and only bout half done with the festy but its coming along1990 Red Festiva STOCK "pregnant roller skate"
Ok son got the rims they are 14 x5.5 with 38mm offset. I have stock kyb struts what tire size should i run that will clear. Will the 165/60/14 still work?1990 Red Festiva STOCK "pregnant roller skate"
yes, that's a perfect fit!Trees aren't kind to me...
ok thanks I got a lil hestate just sitting the rim up there without the tire. cant wait to get some rubber around them see how it looks1990 Red Festiva STOCK "pregnant roller skate"
