Went to the salvage yard. From an early 90's Saturn, got a auto dimming, compass and temp. rear view mirror for my '93 Festiva. mirror.jpg
Do not get the one w/ OnStar! And don't forget to grab the temp sensor from behind the lower grille.images9AHGYN8I.jpg
The factory wiring runs from the mirror all the way to the back under the headliner. Get as much of the wiring harness as you can.
Only four tiny little wires to hook up.
Yellow = power w/ ign. on wire.
Black = Ground
Gray wire and Grn. w/ blk stripe wire = to temp sensor.
Green = to back up light power. (Optional)
Remove existing mirror. Up to you what you do with the hole in the headliner. I put the mount cover back on to cover the hole.
With the special mirror mounting glue kit, locate and glue on the metal mirror mount.
Install the mirror and run the wires.
To calibrate the compass, just find a parking lot and drive in a few circles.
WORKS GREAT!
Black = Ground
WORKS GREAT!
