Handmade valour cargo cover.
  • Handmade valour cargo cover.
    Peg board + chisel + duct tape + Curtain rods + screws + thumb tacks + a nice soft blanket + sweat + 5 hours. So worth it
    Yellow - '91 Festiva L - 5 speed
    Oops wrong picture. Smooth
        Looks good! I have accumulated the materials to fab 2 for my cars. I've only lacked motivation and a break from the summer heat in my shop to get on it. Hope mine turn out as nice.
        "Blue92"- 92L 5 spd, original owner- 185K, B8,DD..
        "Pedro"-88L 5-spd, B6D (built by Advancedynamix)
        "Blanca"-92 GL auto, 125K(FM8 Lowest Miles)- B6 daughter's DD
        "Tractor Blue"- 89 L auto, 110K
        "Chester"-88 LX, runs but not street legal
        "Wenona"-89L parts car
        "Flame"- 89 LX 5 spd ,parts car
          Looks great. More pics of the structure of it? Any WIP pics?
            Originally posted by burundon View Post
            This looks real good. How about a few details stepping through how you fabricated it?
            Thanks.
              Sure I didn't take any pictures during. Was too busy hiding from my wife and sweating. 100 degree days here. I'll write up my steps a little later. It was kind of discovery in progress. 0 plan
                1. Trace opening in place on cardboard.
                - Two pieces with a gap for hinge effect.
                2. Trimmed to fit in the grooves.
                - check for fit, trim as needed.
                - start over because you trimmed too much
                3. Use template to mark the board for cutting.
                - I just used what i could find in the garage. I had a sheet of hard board.
                4. Cut out form with a chisel.
                - Because I had one and nothing better to cut with.
                - start over because you cut too much.
                5. Set in place and duct tape two pieces together.
                6. Remove and wrap entire thing in duct tape.
                - test by leaving it in the sun for a couple hours. Return to find what looks like a tape taco.
                - start over.
                7. Add metal rods (curtain rods) for support.
                - drill pilot holes from top, attach rods to bottom.
                8. Cover with blanket that happens to match interior.
                - fasten to bottom side with staple gun.
                - realize staple gun is broken.
                - use thumbtacks instead
                - realize thumb tacks are too long
                - clean up blood
                9. ?????
                10. Profit.
                  Great write up.
                  I would like to add to step #7 ....... break drill bit off. Slice finger while removing broken drill bit. No band aids in the house so use duct tape from step #6 to wrap finger.
                    That's too funny. I did in fact break a drill bit trying to drill the pilot holes, but didn't bleed on that one.
