Can anyone show me some up close pictures of how their hatch cover works?
Mine doesn't appear to have the string to hold it up on the posts, but it does
have a string running through the lower side of the panel (when raised).
I also have a tach cluster that the needle falls below zero when the car is off
so when you turn the car on the RPM's sit a little below zero. It appears the
needle registers the tach. Do I just put a black painted finish nail in there at
zero so it cant fall any lower or is there a proper way to fix this?
