What does a door weigh?
  • What does a door weigh?
    I have a spare 93 Festiva for proto-type work for my other 93 Festiva racer. Better to cut up a bad car than the good one!
    In the quest to lighten the car, I cut apart the damaged driver side door today and weighed everything. So here are the weights:
    Entire complete door, wind up window, no speakers: 66.2 lbs
    Window glass 9-lbs
    Window regulator, outside mirror, interior door panel, door handle 6.4 lbs
    Inner steel frame work (were the window crank mounts) 4 lbs
    Entire window frame (part of the upper door) 3.2 lbs
    Outer door skin, hinges, locks and the huge safety beam inside the door 43.6 lbs
    So by gutting the door you can lose 22.6 lbs per door
    I think the safety beam weighs 15 lbs (it is pretty massive), so you can probably get a steel door down to around 28.6 lbs
    So for 2 doors, you could lose 75.2 lbs
    You would gain some weight for a window net or a fixed thin plexiglass window.
    Some where down the road I'll make a female mold for laying up fiberglass "shell" doors. I would guess that they would weigh around 10 lbs each
    With fiberglass shells, the weight for 2 doors would go from 132.4 lbs down to 20 lbs.
    Why all the bother? The weight you save in the 2 doors can be translated into a roll cage that stiffens the car and makes it safer, without increasing the overall weight of the car.
    Doug
    interesting. it'd be nice to have a sticky listing weights of the major components. i was surprised how much the whole bumper-re-enforcement assy weighed when i took one off. lotta weight fighting change of direction right out at the end of the car. same with the hatch n glass. never had one off but did remove the strut and it felt way heavy just trying to hold open by hand.
    how do you way the parts? if i can, i hold the part close or overhead on a digi scale and subtract that reading from my previously read body weight.
      FMS used to sell a fiberglass hatch, just FYI.
      91GL BP/F3A with boost
        I did the my weight plus part minus my weight on the digital scale.
        I have a bare front bumper laying around and the foam - I can weight that up in a few days.
        Also plan on removing the rear hatch and seeing what it weighs. It is heavy as all get out.
        Doug
          the window weight really surprises me since i've had them in hand before. no wonder the winding mechanisms go bad. 20+ yrs crankin up and down a bag of potatoes.
            Saving weight ... Carb car doors don't have the safety beam and weight is much less . Also the carb dash is at least 15 lbs less as well .
            New build on the way .
              Trade yet?
              Sent from my SCH-I535 using Tapatalk
