i purchased a rear window with defrosters, and the switch for the bezel up front. what else do i need to hook this thing up. im in utah, and not having a rear defrost is killing me during the winters. any help would be great. i am missing probably 25 pages from my owners manual, so im not sure if there is anything in there.
what do i need to make it work?
There should be the plugs to wire it up behind the black speedo surround. 5 screws to remove(phillips) then just pop out the blank, plug the button into the surround, plug wires into the button, and reassemble.
Now by the drivers side taillight there is a plastic cover that lets you access the wires the plug from the hatch should be lead through there from the top access hole down inside the C-pillar. The plugs should match right up.It's a good thing you don't read the stickies, you might of learned something.
Poverty produces creativity
