Let us not confuse this with the "clear jdm" tail light craze of the 2000s lord those were disgusting.. I'm talking white/frosted I think is a really nice touch on a clean car matching to the front clear corners
So most guys heat the housings so the lenses are unglued and there is 2 layers a plastic the outer is clear and the inner has the coloring so they separate the layers and frost the inside of the outer layer
I do not believe this will work for the festie as I'm pretty sure it's one layer that's colored
Is there anyway to undye plastic or will we need to make new lenses
Sent from my XT1585 using Tapatalk
