ok... so you seem to know alot about suspension geometry and stuff ....
lemme ask you this... theres a guy with chevy one ton springs in his festy...says it lifts it 5 inches....wouldnt that pidgeon toe your front wheels? if so...if you built drop brackets to lower the rest of the suspension how much lower do you think it would have to go to make the wheel right? say i wanted it up 10 inches... would i have to drop all the control arm mounts, sway bar mounts and rear axle mounts 10 inches AND add taller springs? or we talking 5 inches of spring and 5 inches of mount dropping? what would be the ratio of spring lift to suspension lift? all of this goes on droppping the motor a good 6 to seven inches to keep the axles right, as well as fabbing some tie rods ...any suggesions? any answers? im not too keen in suspension geometry and and would like to ride 22's or bigger with out eating tires ... as for brakes.. im thinkin egt disc swap... pwered by b6t.....???????????????????
have car ... need welder.... story of my life
ops: I know that was kind of twisted and gross but I know I am not the only person thinking it. :twisted: Well anyway, I agree with you as well.
