let me tell you a little about what im trying todo, i bought some stock alloys off of hyundai accent that measure 14x5 with a 4 bolt by 4.5 pattern. the problem is that the rear tires will rub and i need to use wheel spacers. in doing so i am sure i need to extend my threaded studs for the 1/4 inch wheel spacers i will be using.
question being, what have others done when using spacers to change the offset of the wheel. or what bolt have you used to extend to the hub? thanks for any info..much appreciated.
