15x8 sport max wheels
The ad says that they won't fit front wheel drive cars.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
Offset don't mean $h*t, it's the backspacing you should be worried about as that's what causes clearance issues. Offset is just the measurement of the mounting surface from the centerline of the wheel... example: 16x6 and 16x8 wheels can both come with a +35 offset, but only the 16x6 wheel will fit a festiva because the added inch of BACKspacing on the 16x8 will hit the strut and swaybar (when turned). you need to know what clearance you have from the hub surface to your strut and figure the backspacing of the wheel for propper fit. the 15x8s you're looking at have a 4" backspacing with the 0 offset, meaning that they WILL fit without touching any suspention component, BUT, they will also stick out past your fender and can posssibly rub the fender lip during suspention jounce.Trees aren't kind to me...
i know the standard offset is 38, but FestYboy and FB71 are right. i think the wheels would look sweet with an fms kit, fender flares, and if the car is lowered. all im conserned about is if the wheel will hit the strut. if not than i guess i will have to get the ones without the huge lip.no more festy but im lookin
87 AE86 GTS 13b swap
92 Escort GT
Originally posted by FestYboyOffset don't mean $h*t, it's the backspacing you should be worried about as that's what causes clearance issues. Offset is just the measurement of the mounting surface from the centerline of the wheel...
Zero Offset. Indicates the mounting surface is at the wheel center.
Negative Offset. Indicates the mounting surface is behind (or inboard) the centerline of the rim. This is often found on standard rear-wheel-drive vehicles and on so-called reversed rims. (Diagram below shows negative offset)
Positive Offset. Indicates the mounting surface is in front of (or outboard) the centerline of the rim. This is often found on front-wheel-drive vehicles. Stock Tacoma wheels have Positive offset.
Backspacing=The distance from the mounting surface to the inside lip of the wheel. This measurement is closely related to offset (without actually measuring, backspacing is about equal to [Wheel Width / 2] + [Offset] + [about 1/4] )
So maybe it does mean anything...
I'm not seeing you fit 8 inch wide rims with out cutting off the rear quaterpanels. I know with fms springs the tires are inside the quarterpanel.
In the morning I'll go measure the width between the strut & quarterpanel.It's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
Originally posted by muscle_Car1Originally posted by FestYboyOffset don't mean $h*t, it's the backspacing you should be worried about as that's what causes clearance issues. Offset is just the measurement of the mounting surface from the centerline of the wheel...
In the morning I'll go measure the width between the strut & quarterpanel.Trees aren't kind to me...
So both a vehicle's horsepower & a rims off set are arbitrary measurements?
How so? They lack any rational basis?
The "horse" in horse power yes. Its very optimistic that a horse could pull 180lbs around a 24ft circle 144 times an hour, but not the math behind it.
Now maybe dave colemans monkey power is a fun one. One HP is .33232628398791540785498498425982 Monkey Power
Backspacing is important, but not all powerful.
I agree with perucho, on its not a magic number. By definition its the distance from the center line of the wheel.
So if 4in=101.6 & 8in=203.2
center-line of each is
50.8mm 101.6mm
+ 38mm offset
88.8mm 139.6mm
139.6mm-88.8mm = 58.8mm
or about 2" difference in backspacingIt's a good thing you don't read the stickies, you might of learned something.Poverty produces creativity
