WOW , so my S-10 wheels are 16" wide ..cool :lol:
15x8 sport max wheels
HD2500 Duramax Chevy
Z28 LS1 power 500 +
Originally posted by muscle_Car1
So if 4in=101.6 & 8in=203.2
center-line of each is
50.8mm 101.6mm
+ 38mm offset
88.8mm 139.6mm
139.6mm-88.8mm = 58.8mm
or about 2" difference in backspacing
that's a 2" difference in backspacing
P.S. i'm not about to have this turn into a flame, just trying to stress what's more pertinant to the issue at hand: "will these fit?"Trees aren't kind to me...
Originally posted by packrat427WOW , so my S-10 wheels are 16" wide ..cool :lol:
As an example a wheel that is 14x6.5 is actually 15x7.5 overall. Does that make sense?
edit: I just saw your truck! I thought you had normal wheels and I was doubting that they were that wide. WOW!Oscar
Yes, these will stick out past the fender and Qtr a lot! But if you pulled and rolled them its would look really good. I think it would put higher stress on the bearing, but if you lightened the car to it would be very little increase another thing a lot of ppl put narrow tires on these rims which would decrease that stress as well.
Thanks :wink:
well the car is gutted and i am getting the fms hood and fiberglass hatch... but i think ive decided on these instead.
Discount Tire Direct is retiring, but check out our partners at Tire Rack! With tires and wheels for virtually every vehicle make and model, Tire Rack is your new source for the best prices and selection for online and mail-order purchases.
but thank you all for the help.no more festybut im lookin
87 AE86 GTS 13b swap
92 Escort GT
I crunched some numbers according to what you guys said... For a stock wheel, half the width is 2", plus add 1/2 inch for the lip, convert it in mm and add the 38 mm offset gives me 152mm backspacing. So I searched for common wheel sizes and stumbled upon a 15 inch wheel, 7 inch width in 35 mm offset, which, after all the calculating is done, gives me 162 mm backspacing, for a difference of 10mm. Now, 10 mm isn't very big, it's a tad bigger that a 1/4 inch, but is it a big deal in fitment? Would that have been rotarykidd's best choice of size instead of the one advertised for that sportmax wheel?The left lane? Are you crazy!!! I never drive in the left lane...It's full of freaks driving the wrong way and charging right at you!!!
Originally posted by Pocket_RocketI crunched some numbers according to what you guys said... For a stock wheel, half the width is 2", plus add 1/2 inch for the lip, convert it in mm and add the 38 mm offset gives me 152mm backspacing. So I searched for common wheel sizes and stumbled upon a 15 inch wheel, 7 inch width in 35 mm offset, which, after all the calculating is done, gives me 162 mm backspacing, for a difference of 10mm. Now, 10 mm isn't very big, it's a tad bigger that a 1/4 inch, but is it a big deal in fitment? Would that have been rotarykidd's best choice of size instead of the one advertised for that sportmax wheel?
As a check, 152mm is 6" which is even wider than the wheel.
On a 7" wheel (8" overall) with 35mm offset you have 5.38" of backspacing (or 136.6 mm). So if you compare both wheels the 7" wide wheel has almost 1.4" more backspacing than the 4" wheel. I would imagine that you will have problems with that.Oscar
also remember that the added inch to the rim width is a rule of thumb and NOT aplicable to every rim out there. use it as a safety buffer/cusion.Trees aren't kind to me...
