I am sure 15's would fit because your spare tire most likley is a 15.
aspire/rio knuckle comparison
Hyundai aquired Kia in 1998, so proliferation of Hyundai engineering (hacked-up Mitsubishi) didn't really occur for 3 or 4 years. So Kia's Mazda based parts continued relatively unchanged till about '01-'02Jim DeAngelis
kittens give Morbo gas!!
It's possible the front brake change in model year '02 was due to some consolidation of parts between the two makes.
No, probably not. I found a Kia Forum site and here is one thread:
One guy says the only difference between the first Rio hubs and the late '02 model is that the lug bolts changed to lug studs.
We shall see.
I am very interested to see if Rio rotors will bolt onto Aspire Hubs, if it's possible i'll be ordering some new parts :lol:
pic shows rio knuckle diagram. part#5 is the spacer. same for all rio's 2000-05. upper pic shows bolt style hub. applies to rio's built from 5/10/00-7/01/02. lower pic shows stud style hub. applies to rio's built between 7/01/02-6/15/05. hubs are not interchangable. there are 21 shim sizes. if you need part#'s for any rio parts i will post.
it almost seems like this is one of those situations where you need to try it out
so would it be worth while for me (since i have the aspire swap on my car) to buy a rotor for a Rio and see if it will bolt on to my car?
worst case senerio is i have to return the rotor and get my money back
does the rio knuckle have the same goofy bearing setup as the aspire/festiva ?Contact me for information about Festiva Madness!
to answer your question, yes.
Now, I have a question.
Why does everyone think this bearing configuration is goofy?
Taper roller bearing require a certain amount of preload to operate correctly. The select-fit shim configuration is the most reliable method to set preload. While it is an inconvienience to us while replacing the bearings, I really wouldn't call it goofy. I'm guessing noone here has rebuilt Dana axles? The light duty axles use a crush sleeve (same as Ford and GM, Stirling Axle and American Axle), but the heavier duty axles, like the 60, 80, 90, S110 and S135, use select-fit shims. Ok, I'm done my rant...Jim DeAngelis
I prefer an easier setup to deal with, and have no clue how to change these bearingsContact me for information about Festiva Madness!
