aspire/rio knuckle comparison
    I am sure 15's would fit because your spare tire most likley is a 15.
      Hyundai aquired Kia in 1998, so proliferation of Hyundai engineering (hacked-up Mitsubishi) didn't really occur for 3 or 4 years. So Kia's Mazda based parts continued relatively unchanged till about '01-'02
      Jim DeAngelis
      kittens give Morbo gas!!
        It's possible the front brake change in model year '02 was due to some consolidation of parts between the two makes.
          No, probably not. I found a Kia Forum site and here is one thread:
          One guy says the only difference between the first Rio hubs and the late '02 model is that the lug bolts changed to lug studs.
          We shall see.
            I am very interested to see if Rio rotors will bolt onto Aspire Hubs, if it's possible i'll be ordering some new parts :lol:
              pic shows rio knuckle diagram. part#5 is the spacer. same for all rio's 2000-05. upper pic shows bolt style hub. applies to rio's built from 5/10/00-7/01/02. lower pic shows stud style hub. applies to rio's built between 7/01/02-6/15/05. hubs are not interchangable. there are 21 shim sizes. if you need part#'s for any rio parts i will post.
                Didn't the Festiva have 21 different shims also???
                93 GL modyfied!!!
                :fish:
                  it almost seems like this is one of those situations where you need to try it out
                  so would it be worth while for me (since i have the aspire swap on my car) to buy a rotor for a Rio and see if it will bolt on to my car?
                  worst case senerio is i have to return the rotor and get my money back
                  • #24
                    yeah I think its just gonna be a matter of time until somebody buys one and trys it out.
                    • #25
                      does the rio knuckle have the same goofy bearing setup as the aspire/festiva ?
                      • #26
                        to answer your question, yes.
                        Now, I have a question.
                        Why does everyone think this bearing configuration is goofy?
                        Taper roller bearing require a certain amount of preload to operate correctly. The select-fit shim configuration is the most reliable method to set preload. While it is an inconvienience to us while replacing the bearings, I really wouldn't call it goofy. I'm guessing noone here has rebuilt Dana axles? The light duty axles use a crush sleeve (same as Ford and GM, Stirling Axle and American Axle), but the heavier duty axles, like the 60, 80, 90, S110 and S135, use select-fit shims. Ok, I'm done my rant...
                        Jim DeAngelis
                        • #27
                          Yeah I agree Jim, I guess everyone just has there own preferences but I am sorta partial to these bearings, oh well.
                          • #28
                            Hey, I don't know if this is the right place to post this, but how hard is the swap from the festiva to the aspire/rio setup. What is involved...?
                            • #29
                              well the aspire is a direct bolt up, you use festiva lower control arms/ ball joints and you use aspire/323 tie rod ends.
                              • #30
                                I prefer an easier setup to deal with, and have no clue how to change these bearings
