Springs,spindles, tie rods control arms, Rio,aspire, festiva.Im confused
  • Springs,spindles, tie rods control arms, Rio,aspire, festiva.Im confused
    Okay my green car is Rio front swapped with cut aspire springs.prior owner built or I'd know what was done.Well a spring just broke I have tomorrow only to fix the car.The junkyard is 4hrs round trip the parts store is 1.5 hrs round trip So I have to get everything right the 1st time.I have a stock festiva parts car.If I put stock festy springs and struts on. What surprises will I run into.If I go to the salvage yard and grab full aspire frts what surprises am I on for. If I just go back to all festy what surprises am in for.Spindle heights all close enough? Inner tie rods all the same? Ball joint diameters all the same? Will festiva, aspire, and Rio spindles all work with the same control arms?Last but not least will a 12 inch trailer wheel bolt onto festy spindles. I ask in case I get a flat and have 2 bolt patterns I can keep my aspire spare tire in the car and buy a boat wheel if I need a different spare.1 more 1 last thing, can 1 put aspire hubs on festy knuckles?
    Here's a simple plan. Can I put festy springs on Rio struts?
