what all is needed from the aspire? Also are the driveshafts the same between the aspire and festiva?
festiva with aspire suspension
Here it is: http://www.fordfestiva.com/forum/viewtopic.php?t=144. Wil did a nice write up on this. The axles are different (longer?). Don't forget to grab the spare tire from the aspire since your bolt pattern will be changing and he festiva spare will not work.
matt
You need the Aspire steering knuckles with the brake hoses. Then you need the entire rear beam with it's brake hoses. You will need the Aspire E brake cable, or you can figure out how to make the Festy one a little longer which is the way I did it. Then of course you will need a set of 4 x 100 wheels and tires. I'm still using the Aspire steelies til my tires wear out. Then I'm gonna put on my Miata 14" wheels. Good luck! Sorry for the delay responding.
Not found error 404 please work I need info please give me different link for stickie...I'm doing this in one day in about two weeks so any help would be nice. If I was to bring a list of what I need to bring so I can see what I got and what I need to order...I don't like paying high retail prices and driving back in forth to a store to have to order. And have no car.Originally posted by mattswabb View PostHere it is: http://www.fordfestiva.com/forum/viewtopic.php?t=144. Wil did a nice write up on this. The axles are different (longer?). Don't forget to grab the spare tire from the aspire since your bolt pattern will be changing and he festiva spare will not work.
matt
Sent from my SM-T377V using Tapatalk
