what all is needed from the aspire? Also are the driveshafts the same between the aspire and festiva?
festiva with aspire suspension
Here it is: http://www.fordfestiva.com/forum/viewtopic.php?t=144. Wil did a nice write up on this. The axles are different (longer?). Don't forget to grab the spare tire from the aspire since your bolt pattern will be changing and he festiva spare will not work.
matt
You need the Aspire steering knuckles with the brake hoses. Then you need the entire rear beam with it's brake hoses. You will need the Aspire E brake cable, or you can figure out how to make the Festy one a little longer which is the way I did it. Then of course you will need a set of 4 x 100 wheels and tires. I'm still using the Aspire steelies til my tires wear out. Then I'm gonna put on my Miata 14" wheels. Good luck! Sorry for the delay responding.
Originally posted by mattswabb View PostHere it is: http://www.fordfestiva.com/forum/viewtopic.php?t=144. Wil did a nice write up on this. The axles are different (longer?). Don't forget to grab the spare tire from the aspire since your bolt pattern will be changing and he festiva spare will not work.
matt
Sent from my SM-T377V using Tapatalk
