seems like some other guys have taken between one full coil and 2 and a half coils out and maintained their stock ride quality. I'll probably start with 1 coil and go from there. i've driven RIDICULOUSLY low cars daily in the past, but im not looking for that at all... more or less i wanted to make the center of gravity slightly lower and possibly reduce a little bit of body roll. i think a coil or 2 can do that for me Thanks for the help guys
Chopped Springs -- YAY or NAY ?
1988 Festiva: $50 Daily Driver (170k miles)
'96 Civic Hatchback: K20A2 All Motor; 12.55@108.55mph
http://s54.photobucket.com/albums/g8...Civic_0002.flv
Originally posted by 187festiva View Posti have never cut the coils what i did on my bp festiva is get a buddy to heat the coils with a burns-o-matic then when there red hot get the fat kid(me) to stand on the bumper. doing that dropped mine about 2 inches and still rode nice
-Aspire brake swap COMPLETE!
i only made that post once. not sure why it continues to re-post the same thing over and over again, but it wasnt my doing...hell, i wasnt even on this site for the past week, but is shows me posting on the 15th and 16th. go figure. if it happens again, just disregard it. my appologies. i got the answer to that question by now...lolLast edited by 88smartcar; 01-19-2009, 06:10 PM.1988 Festiva: $50 Daily Driver (170k miles)
Originally posted by 88smartcar View Postseems like some other guys have taken between one full coil and 2 and a half coils out and maintained their stock ride quality.Last edited by ejp2fast; 01-21-2009, 12:28 PM.
^^ provided the spring hight remains constant.
don't heat your springs with a torch!!! (this falls into the Dumb Ideas list) it drasticly changes the spring rate and not for the better! i've personally seen the results of such behavior and it ruined the car and made it unsafe to drive (customer had to have the car towed from the shop after discovering what he and his friends did to it.)Trees aren't kind to me...
You can chop them all you want, but then the problems with the drivability of the car come. You can have the spring shift in place if it unloads enough. Give it a try and see what happens though. You never know, I've seen people get lucky and not have any problems after cutting or just heating and bending."If you're not first you're last!" -Ricky Bobby
-91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
The little Festy that could...and did!
(Gone on to a new life)
-90 Ford Bronco II Eddie Bauer
Originally posted by SIBladerunner View PostYou can chop them all you want, but then the problems with the drivability of the car come. You can have the spring shift in place if it unloads enough. Give it a try and see what happens though. You never know, I've seen people get lucky and not have any problems after cutting or just heating and bending.
Originally posted by Otakuphill View Posti cut mine 2 coils and it rides great. It feels allot more stable to me.
