FMS springs question
  • FMS springs question
    Just out of curiosity...do you need spring compressors do install the FMS springs and KYB's? Like a spring compressor to get the old ones off and the new ones on?
    ^ Yes
      Just on the front.
      93 GL modyfied!!!
      :fish:
        ahhhhhhhh..................... only to remove the old springs.
        the new ones will go on quite easy without compression.
          yes. no.
          do you NEED spring compressors, no. I removed my (front and rear) stock springs w/o compressors, because it was easter day, autozone was closed, and i wanted to get the job done. but it is NOT recommended. Since i was putting coil overs on i didn't need a compressor to re-assemble, so through some careful working with the jacks i was able to remove the front struts+springs without having any type of compressor. So it can be done, its just not recommended! proceed at your own risk.
          ~Nate
          Current cars:
          FOTY 2008 winner!
            Originally posted by skeeters_keeper
            yes. no.
            After the accident Skeeters randomly gave people the thumbs up symbol with a huge smile....
              Spring compressors are a free loaner tool at autozone. Almost no risk when using them. I say use 'em
