hey what all do u need to do the brake swap the claipers,rotors and what else
aspire brake swap
If you can, grab the entire front suspension setup and alllllll the bolts. I found this out the hard way... You def. need Aspire Control Arm Bolts, Festiva ones aren't long enough to work properly as well as tie rod ends. If you have any questions about it feel free to IM me thru the AIM button... -KyleCosmic Blue 2008 Mazdaspeed 3 - Mostly Stock...
White 1990 Ford Festiva - B6 SOHC powered 50 shot = 14.5 @ 94 mph Gone but not forgotten
Proud member of Chicken Mechanix Racing
assfire struts will raise your car...unless thats what you want, don't get them.Wil
02' Sc00by WRX Sedan (current project)
00' Celica GT Automatic 38mpg gas-sipper (sold)
05' Scion xB box-on-wheels (sold)
93' MX-3 Hybrid on LSD (sold)
96' Slowtegé 42mpg Beast-mobile (engine exploded)
93' B6-ZE 'tiva GL aka"Blue Bomber"(now owned by darpien)
nothing wil change but the brakes??!!?
If you swap Aspire brakes, you haven't changed anything but the brakes. The ride height will be the same, i.e. stock (depending on your tire selection).
If you *choose* to use the Aspire suspension your ride will be higher.
If you *choose* to use a lowering suspension your ride will be lower.
If you *choose* to use the stock Festiva suspension, your ride will remain stock.
Brakes and suspension are two different things, I think that;s what folks are confused about. The suspension parts are all interchangeable.
Originally posted by KindredWill the FMS lowering springs and struts return it to close to stock height?
Here's an idea, why not use FESTIVA struts??? They will keep it at stock height and if you have the money, buy the B+G, er...sorry, FMS lowering springs along w/the struts.Wil
nope, the assfire struts & festiva struts are somewhat the same but not entirely.
I dont' know why but the assfires raise the rear end somewhat (maybe stiffer or the perches are higher? i dunno).
the stock struts are fine if you do this swapWil
