i just got in from finishing the front half of the aspire swap, took it for a drive (with open headers at 9:00 at night, my neighbours hate me lol) and OMFG what a difference, with the aspire shocks and sway bar it stays so level through the turns its amazing!!! i love it. also i got the egt calipers and rotors, but that is still not good enough, i got drilled and slotted rotors with high performance pads. when i hit the brakes it feels like i hit a wall. i love it.
aspire swaps kick but
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
did the sway bar fit right up to your control arms? and how hard was it to change sway bars i notices they are different the aspire curves up in the middle? i am thinking about doing that to my car and i just replaced my control arm and well i don't want to have to get a different control arm for the sway bar...
1989
Ford Festiva L
Automatic
it fits right in.
awesome i love you i wish i would of know that cause i spent about five hours working on my car today and well i would of went to the yard and picked me up one... i was sad when i ran out of things to do... so what about the notch in it... can you send me a pic of it to help me out?
1989
Ford Festiva L
Automatic
put a jack under the cross member, loosen the bolts, lower down the cross member and slide in the bar, jack it back up and tighting the bolts, put the ends of the bar in the the lcas, put the mounts up to the frame and tighten those. your done.
so the cross members are in the same spot i take it... so were the shocks strait from a junk yard or did you but them new? i plan on going and buying from the local yard every thing i need for the swap as soon as i get my free government money.. yay... free money..
1989
Ford Festiva L
Automatic
aspire struts are the same....spring is a little taller...so raises your ride height but an inch or so"FLTG4LIFE" @FINALLEVEL , "PBH"
i got everything from the jy other than the rotors and pads. anyone who has the chance to do the aspire swap, DO IT, it is totaly worth it.
for the fronts so far i have spent about 120 at the jy and 70 on the rotors and pads. but i forgot that you dont use the aspire lca,s so in getting my money back for those. im also exchanging the egt calipers for the regular aspire ones, they dont fit quite right, ill get some pics later. also with the aspire ones i can use 13" rims, and then i can use up the 6 slicks i have in my shop
its a 5spd, i bought it that way. lca stand for (Lower Aontrol Arms). if you are doing that aspire swap on a auto you have to find all the parts off of a auto car. but i cant remember for shure. anyone know for shure?
