ok i ordered some rims but i dont know what size tire will fit on the rims. the rims are 14 x 6 so does it matter what width i use? i mean granted that it dont rub? im confused i tried searching for a better definition but i couldnt find anything,
dumb question
Put in the 195/45-14 as a reference... See how much it differs from there....
A 205/55-14 is almost an inch larger... The 205/50-14 is a half inch larger.
I think with both of those, you may run into issues if you're lowered at all; at least with rubbing over bumps and stuff, turning could be an issue too.
The dumbest thing would be to order the tires that won't work... If you want Toyo Tires, they make them in 195/45's and they're not terribly expensive.Simon - pimptiva.com
Toyo proxies I have seen yesterday on the web 195/45/14....65 bucks I thinkOriginally posted by Hot_Wheels View Postok im looking at BFGoodrich drag radials there 205/50/14 i really like the Toyo proxes R888 but they only come in a 205/55/14 with that little bit taller matter?"FLTG4LIFE" @FINALLEVEL , "PBH"
