dumb question
  • dumb question
    ok i ordered some rims but i dont know what size tire will fit on the rims. the rims are 14 x 6 so does it matter what width i use? i mean granted that it dont rub? im confused i tried searching for a better definition but i couldnt find anything,
    I used 195/45/14 tires on my 14x6 without any issues.
    93 GL modyfied!!!
    :fish:
      ok to find a good selection of drag radial it seems 205 is where there at can i use that or you think i will have issues? thanks Brian for being so quick
        It would depend on the height of the sidewall whether you could run a 205 drag tire. Do you know the diameter?
        93 GL modyfied!!!
        :fish:
          I've used this place for YEARS when I had tire questions.
          205's in a 40 or 45's may work. On my 14's, I ran 195/45's as well.
          Simon - pimptiva.com
            ok im looking at BFGoodrich drag radials there 205/50/14 i really like the Toyo proxes R888 but they only come in a 205/55/14 with that little bit taller matter?
              The 50 and 55 are a percent of the tire height. Here is a tire calculator to help you. Its only a small difference.
              Selects a tire width, select an aspect ratio, and a rim diameter, and click on calc. The program calcs the correct tire diameter. this number can then be compared to the MFR original tire diameter.
              93 GL modyfied!!!
              :fish:
                well i get that and thanks for the calculator but how would i know if a 50 or 55 would be to tall? with a 14 in rim?
                  Put in the 195/45-14 as a reference... See how much it differs from there....
                  A 205/55-14 is almost an inch larger... The 205/50-14 is a half inch larger.
                  I think with both of those, you may run into issues if you're lowered at all; at least with rubbing over bumps and stuff, turning could be an issue too.
                  The dumbest thing would be to order the tires that won't work... If you want Toyo Tires, they make them in 195/45's and they're not terribly expensive.
                    Toyo proxies I have seen yesterday on the web 195/45/14....65 bucks I think
                      i want a drag radial though
