I found this, use the pull down list to find ford festiva 88-93:
Chrome lug bolts/nuts
I finally found some and bought all they had (35). Elusive piece of hardware. Exspensive too. $94.28 for all of them tax included.
Photo op while I had the camera in my hand
Wouldn't it be a lot of trouble to remove the rotors and/or hubs to get the lug holes bored then the studs pressed in just for chrome lug nuts? Or, are you guys just installing a threaded stud into the existing threaded holes? Truck stops have chrome lug nut caps for about 50 cents. They are a little large for a Festiva though.
^ I could probably get you some. Probably about $3 each with shipping to Waianae. Maybe more , 16 of them are pretty heavy. I havent tried the ezAccessory.com TdDaffyFestiva suggested as I had already ordered these. Might be able to get them cheaper on that site.sigpic
Here's what I used on mine....
Bottom of the page, 2nd from the left. 12mm x1.5 thread. 1 1/2" long.
The '89 I got for my daughter not long ago had 15 of these plus 1 stock lug bolt. Found a place that has them in stock. They were $1.08 ea. as of 7-26-08. I bought 17 so I can change the '93 over the next time I have it in the garage. Also bought chrome lug nuts from the local auto parts store for $1.00 each.
Hope this helps.
