OK, so I was thinking about how to get some more grip out of the tires and I thought of something.
The car is set up from the factory to understeer. Standard thinking would tell you that to counter the understeer you would stiffen the rear sway bar. Now, the body also rolls excessively under cornering, this messes with the camber and would affect how much grip the tires get, more so up front because there is more weight there.
If you were to stiffen the front sway bar you would get less body roll, and might actually understeer less. The remainder of the understeer could be corrected by a larger rear sway bar. I think in the long run you might get better performance.
Has anyone tried using the aspire front sway bar?
