ok ive done lots of searching and cant find anything. my question is, will the rear beam out of a aspire with abs work in my festiva? is the brake lines the same? are the drums diffrent? dose it have diffrent a e-brake cable? also i cant remember if the only diffrence between the 2 door and the 4 door is the e-brake cable, is that correct?
will the abs rear beam work?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
thanks. im going to pick it up today
