205/60 /13?????????????
  • 205/60 /13?????????????
    Well been looking around for rims and cam upon a guy selling 13 inch rims.
    they are 4x114 but will the 205 rub on stock????
    Yes it will rub, front and back. Not all the time but during cornering and hitting bumps hard, especially when you hit a bump hard while cornering. I ran 205/60/13s for close to 20K, and the front fenders tore up the outside shoulder blocks, same on the back. And the back ones also got a 1/4" groove on the inside shoulder block from the bottom spring mount on the shock. But I rolled the front fenders in after a couple thousand miles and while the tires still scrubbed a little, it didn't really tear them to shreds anymore. But bottom line, yeah they scrub, but you can use them, especially with a little modification of the fender wells and maybe the spring mounts
    No festiva for me ATM...
      htchbck, what offset were those rims? Width? Have any pics?
        Offset I believe is 35mm, but in not 100% on that, may have been 40mm. They are 13x5s, dual drilled 4x100 and 4x114.3 (fits aspire swap and stock festy pattern). Here they are.
        and on the car
        pm me if you're interested in them, they might be for sale
          i've never seen wheels that are drilled so close together.... hardly seems structurally ok...
          -Aspire brake swap COMPLETE!
            ^^^ lol it might not be, but they never cracked or fell off the car lol. I wouldn't recommend offroading or autocrossing with them, but i never had a problem with them
