festi wheel 4X 114 or 4X114.3 and what rims are good to put on im lookin at 15 in rims i wann put on but i dont wanna do an entire swap
another quick Q
another quick Q
Frankie
fully custom 88 festy (project doomsday) Febuary in 2012 calander
Blockspire: ken block replica aspire
AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
that doesnt help much i must not understandFrankie
wcbarker, your a better man than I!
But, look's like the handholding isn't enough.
Need to spoon feed now!'93 Blue 5spd 230K(down for clutch and overall maintanence)
No was thinking this:
Telling them to search isn't useful!
Leaving me one of two choices, post the link or say nothing!
I was trying to congratulate you for trying to help this this nubie, when the above is listed under it own forum: "Custom Suspension, brakes & wheels"!
No less as a sticky!'93 Blue 5spd 230K(down for clutch and overall maintanence)
This is even better. I will help you out, since I have used the search function before and came up as confused as ever.
This is what I have on my car now. With 750 miles logged in and ABSOLUTELY NO RUBBING!!!
I have a 15 x 6.5 wheel with a +38 mm offset. It has both bolt patterns 94x114.3 and 4x100) so as to fit other cars as welll including a possible Aspire swap. I mounted 195/35-15 tires. It is very close but works perfectly. LMK and I can get pics front rear side and closeup if interested.
My Festiva came stock with 12 x 4.5 wheel with 4 x 114.3. (the other # you were thinking is 4 x 100) That is what is more common on many other vehicles.-Bryant
Gomez get us some pictures
I just had 2 on my car ....needed something to replace a couple messed up tires...fronts bolt right up...rears you will need spacers....at least with 185/60/14 tires on them. The speedo reads about 3mph slower with those tires also."FLTG4LIFE" @FINALLEVEL , "PBH"
now gomes that is stock swap right festy everything just after maket rims and tires correct?Frankie
I have a set of 99 Sonata wheels, 15x6 with the right bolt pattern, 4x114.3 with 195R50 15 tires, if you're interested.Originally posted by frankm201@yahoo.com View Postnow gomes that is stock swap right festy everything just after maket rims and tires correct?
ChuckChuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
