Just blew the rubber on my 12's and would like to know wat size 4lug rim could i use??? Then whice rubber size?? Just can't tell these days ya know???
Rim and rubber.
Those also don't have tires"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Do the aspire swap and then you have more options"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Yeah, you swap the front and rear parts over to aspire parts and that opens up your options for a greater wheel selection. Instead of the festy 4x114.3 you'll have a 4x100 bolt pattern which is more common.
you may need some spacers to get the wheel out a little bit and farther from your strut, which is where you are hitting... what size 13's are they (Example 13x5" or 13x5.5").. also what are they off of? i ask b/c seeing what the offset is.Originally posted by dragonslit View Posta went to pick and pull and got 4 13 rims all with rubber but 2 r bad and now there rubbing a bit i think it was a p155/80/ r or somin like that.... any guesses on tire size i should use for less rubbing??????
-Aspire brake swap COMPLETE!
