I am kinda of confused of what is on here. If i use an aspire knuckle with hub, can i mount the escort front caliper and rotor on the front to acheive even bigger brakes than the aspires? Has anyone actually done this and is it worth it
aspire knuckles with escort/protoge calipers and rotors
People have done it, you have to use 14" wheels though. No 13" wheels can clear protege/escort calipers. I have a set a protege calipers that need to be rebuilt in the back of my truck.---------------------------------------------------
Yes you can use a stock festiva booster/MC. The caliper will bolt right on the aspire spindle.---------------------------------------------------
i believe the caliper bore is the same and it might even use the same/similar brake pad, but the rotor i bigger in diameter giving more leverage on the hub, hence greater braking power. so that being said, yes you can use the same master cylinderNeil
Jesus loves me. This I know.
93 L track prep in progress
88? Parts car-sold
86 b2000- pisses of HOA-sold
capri swap? 10.2" vented rotors...Trees aren't kind to me...
i have the escort gt calipers on my festiva and they are awesome. and you can fit 13" rims over them... i found some 13" ALUMINUM rims that fit over them, i think the aluminum rims have a bigger center bore to them, compaired to the steel wheels. i took mine off of a 93 escort gt. i THINK the number on the top should say "22V"...
Mike, AKA the sasquatch
i have the aspire swap and escort gt calipers and disks.Originally posted by BUSTIVA View Post^^ are they on the stock discs, or did you swap those too?
