after an hour in tognoties(a local speed shop) with the help of a friend we went through every strut/shock and compared to festiva struts.... here is what we found.
Fronts are 88-91 toyota camery v6 struts... all you have to do is drill out the top of the festiva strut bearing to fit,(lower bolts line up but are over sized so all you need are some oversized washers) and due to the oversized holes you now have some camber adjustment
you also need to cut the spring perch off.
The rears are 96-99 nissan maxima DIRECT BOLT IN!!!!!(with a washer or 2 to take up some clearance) the struts are quite a bit shorter... 3-4 inches... you have to like tucking 175/70/13 tires and know how to roll fenders... cause it gets low
the ride is stiff but awesome and not bouncy.
for the springs im running 88-91 honda civic apc lowering springs with adjusters in the rear.
ill post pic soon any questions just pm
